oldgit
Since purchasing the boat last year port engine will only to 2200 rpm at WOT.
The other will instantly go to recommended max 2600 rpm and stay there all day.
For one reason or another the fuel tank has been drained/cleaned and new filters fitted throughout.
Pretty certain the air supply is more than adequate.
All cables have been checked for adjustment.
Fuel pump has been checked for adjustment.
No smoke(honest) from either.
Both go to 2600 under no load.
Engines now total 350 hours from new.
Pretty certain it is prop pitch.
The existing props were supplied brand new by Vetus as per the original spec supplied by the builder of my boat regards engine rpm,gearbox ratios,weight etc.
But somebody got something wrong.
As it would appear we need to "find " 400" rpm,I think that the port prop needs about 2" on the pitch,to say 22" x 22 ?
What thinks you ?
Oops Starboard prop pitch is now correct.
The starboard gearbox is running in "reverse" and thats the standard ratio for 10 18 106 reduction version.
What thinks you ?
