Prop nut
Generally the softer the material the larger the pitch i.e. use a course pitch in you aluminium mast.
The smaller the pitch the greater the self locking effect and the greater the tension of the shaft/[prop can be tightened for given tightening force.
I have use the smallest pitch on my stainless shaft and nut but if you are using bronze maybe the middle one would be the best compromise.
