Prop nut zinks for Ferretti 480
baylabayla3288
7 Jun 2005
South of Finland
My boat's prop nut zinks are up for replacements. A suggestion for a good source tha can send a pair to Finland is much appreciated. The outer diameter is about 50 mm and it is ca 70 mm long. It sits on a cone at the end of the prop nut itself and is kept in place by a dedicated bolt.
The inner diameter will decide anode size. Some are threaded to screw on, others have a hole and are fitted with an Allen bolt through.
In your vicinity Biltema have up to inner dia 40 mm (part no 252514), for further identification Vetus have some in their e-catalogue, even as kits with prop nut and anode.
I get my bar-anodes from http://www.shipshop.dk/b_dpleje_anoder_zink_alu_mag-c-715_452.html rapidly and fair priced (Swedish language selectable on the site) but think 'any' EU seller will ship to Finland, weight however pushing postage.
Make sure you keep the bolt - not always included with new anodes ;)
Yess I found them in stock at our local Biltema for €9.99 per pies. Some US websites had compatible for sale for over 100USD :-). Once more thank you!
