Prop damage
Tezza
New Member
3 Feb 2004
Midlands
I am buying into a Bavaria 38 in Turkey. On the inspection visit I noted some (slight?) damage to the prop. See pic the damage is on the lower LH lobe.
Any prop experts out there who could venture an opinion on how this might affect performance?
worst case it may cause vibration, cavitation, and palpitations of the wallet.
Otherwise, it looks like a small ding that could wait for a bit, but I'd be tempted to try and smooth it out a bit.
That has probably hit something. Worth taking the prop off and checking the bush in the hub for wear and corrosion. May indicate that the prop is nearing the end of its life. aluminium props like that are not easy to refurbish and are not hugely expensive to replace with new. The damage might cause some extra vibration, but probably not a loss of performance.
BTW it looks like the drive leg and prop have been antifouled with a copper based AF - not a good idea. You may find the prop is also corroded because of that. Best to clean all the mess off the drive and recoat with the correct AF - Trilux is the International type.
Personally, I'd get rid of all the anti-fouling, clean it up properly and see exactly how much metal is missing. A new prop now will be cheaper long term than having to haul out and replace mid season (unless you have dive gear ;)
Put on the correct primer (I used Blakes Paints Prop Primer) and then paint with antifoul (Blakes Paints Mille Drive Spray coat). I also removed the rubber gaitor and re-glued with Sikaflex 292i. This isn't a recommendation for any particular product, they were 50% off in the boat section of a DIY store - so I'll see how they do this season.
(I know I know ... she'll get the bottom soda blasted next winter. :o )
Before and After .....
