Sailfree
Have a feathering prop and 2 anodes on shaft (1 for each year) and one tear drop anode on hull and all are corroding nicely. Intend to put a 3rd on shaft (other 2 appear sound around bolt positions, replace hull tear drop anode (all 12 months old and one 24 months) but just inspected prop anode and its dirty but untouched with no pitting (fitted 6 months ago).
What should the resistance be between anode & prop? I assume this will be same resistance between anode and shaft.
Will obviously check contact surface between anode and prop.
Would you replace prop anode with new or clean it up and reuse?
If you were to clean anode up how would you do it?
