Birvidik_Bob
Morning chums (well, it’s 8:50 here).
Thanks for all your suggestions on my previous post (& Hi Chris – looking forward to seeing you here). To recap & bring things up to date:
Mermaid melody 4 cylinder 90 HP naturally aspirated engine, 1100 hours since new. Regularly maintained according to manufacturer’s recommended schedule. 11 hours since last service (including oil change, new injector nozzles and tappet adjustment – the last two done by a mechanic in Gouvia).
Ran fine for the first 4 hour run to Mourtos. 5 hours into the run to Lefkas oil pressure began to progressively drop and exhaust began to give out increasing amounts of white smoke.
Now the engine’s cooled down I’ve had a look at things. Oil level much higher than it was. Viscosity difficult to determine, but if pushed I’d say it was thinner. No sign of milkiness or emulsification. Coolant level a little lower but not much. Some signs of oil spray from the fitting for the breather pipe that redirects oil vapour into the air inlet. Small signs of oil leakage from two of the studs holding the rocker box cover down.
Another point, which may or may not be of significance, is that there appear to be small amounts of diesel pooling in the wells in the cylinder head where the injectors are fitted.
So – I’d guess it looks like diesel leaking into the oil, but still three questions:
1) What’s the most likely cause?
2) How would this diagnosis explain the white smoke? There was a large increase in smoke over a few hours.
3) Anyone know of a good diesel engineer in Lefkas?
Thanks again
Bob
Thanks again
Bob
