PaulJ6152
New Member
Can anybody help on the following problem, sorry its a bit lengthy but wanted give as much info as possible.
I have twin VP 250’s (the old Volvo 2 ltr single OHC engine) At the end of last year I got water in the fuel tank- leaking seal on filler cap. Both engines wouldn’t start water had got into carbs and engine.
So I removed fuel changed fuel filters stripped all four carbs (Solex 44 PAI’s), changed points, plugs, checked timing (also the advance) dwell and balanced carbs , even checked compression in cylinders.
Both engines now start fine and will run perfectly throttling easily and as I am on the river we don’t normally open the engines up and they run fine. However I wanted to see all was OK so opened up and one engine is fine but the other will not rev properly, its OK till about 2500 and then It seems to be labouring as though not enough fuel getting to it.
I have rechecked the carbs and all seems clear, accelerator pump works fine and the fuel pump is pumping fuel. I don’t seem to have any air leaks.
The carbs only have the idle speed and idle jet adjustment so no much to adjust and assume the normal mixture is set.
One other thing I noticed was, if I opened the idle mixture screw while under load the engine opened up a bit better. So assume the richer mixture from the idle jet was helping so it seems to point to carburettor problem.
Any ideas would be much appreciated as I think I have run out of them.
