John 32i
I launched last Monday and spent the weekend cleaning and ensuring everything works...however when I switched on the water pump for the domestic supply there was a strange noise; a quick look showed that the pumpguard casing had shattered (I guess due to it freezing), I changed this but the pump runs continuously and the water surges out of the tap in the galley, but dribbles out of the tap in the heads. I checked the water level in the tank, there do not appear to be any leaks (water or air) in the pipes/connectors etc and I have left it running for 5 mins to try and ensure there is no air in the system..so question is do I assume that the pump is knackered...again maybe due to the cold weather? Replacement Flojet R4305-505 about £150 so don't want to buy one if its not needed - any advice appreciated!
