Adrianwool
Hello, suggestions welcome on this one. Last November I had a problem where the Starboard engine TAMD41b 'dumped' a quantity of fuel into the bilges, (some 30 litres in total). The engine would idle at 1,000 rpm, but not provide any acceleration. Had the engineers look at this at the time, they determined a 'leak' & replaced the supply and return hoses, & apparently job done. At low speed (sub 1,500 rpm) no problem, took the boat out today for a run, ran the engines up, to 2,500 - 3,000 rpm, and on return to marina found the starboard engine had 'dumped' fuel into the bilges, (not so much this time about 5 - 10 litres), and the engine would provide acceleration. Having the engineers to look again, but would like to bat this round the forum. Is it likely that this is a repeat of the hose problem, i.e. an unfortunate coincidence, or could it be something else, my thoughts were increased pressure associated with increased engine speed 'bypassing' a seal on the liftpump for example. Comments welcome
Adrian
Adrian
