Cymraeg
This is my first post where I attempt to include images, so apologies in advance if I make a mess of it!
I've been to see a Princess 40 which I really like, but am concerned over the state of the mechanicals. The owner claims that oil changes have been performed regularly by a boatyard but “can’t find” any paperwork to support this, although the registration document and VAT invoice were located straight away. My main concern is that there seems to be a lot of oil around the compartment but can’t really tell whether this is down to sloppy ‘maintenance’ or whether there’s (or has been) a more serious problem.
See hull behind engine sumps:-
Also signs of either leakage or spills around the sump gasket on each engine:-
There is an inch or two of sea water in the bilge (it was a disgusting colour so there was no way I was going to taste it) but both shaft seals were corroded so I assume this is where it’s coming from.
The only other major problem that I have found (prior to survey) is corrosion around the side windows:-
Why is this as I thought the windows were stainless, or is it just the surrounds that are stainless with ferrous material underneath?
Otherwise the boat seems in pretty good nick, having under 200 hrs usage. If I can get some assurances on the above (and get the rather stubborn vendor to drop the price a little more as he’s been looking for top dollar for nearly a year) then this one might be a go-er.
Thanks in advance for any replies… /forums/images/graemlins/cool.gif
