BGW
So what affect would putting a pair of 15x11s on or a pair of 15x13s have?
The first number is the prop diameter, the second number the pitch - you could think of this as the 'gear ratio' - the higher the number, the less revs will be required to reach the same speed - but you still need the pitch to be matched to the boat/engine combination.
If you can reach max revs there is no point putting the 11 pitch props on - and I doubt you will get more speed with the higher pitch. - If you can get them changed with little or no cost then it's worth a try.
