JOURNEYMAN
Hi,
New boat with teething issues. Both fridge and freezer stooped working. traced the problem to a split hose between seawater in seacock and pump. Replaced hose. Now can't get the pumps to suck water up and pump through compressors. The compressors and pumps are sited above the waterline level. Have tried undoing, sucking through water then re-joining - to no avail. Have tried detaching pump, bringing it down to waterline level - it fills with water, but when raised, goes dry again.
I guess gravity is the enemy here?
I guess its unusual to have the pumps above waterline plane so they need to prime. There is no priming pump or screw or anything that I can see on them. The boat was on the hard to 2.5 years before I bought her. I guess it would drain the system. But the freezer id 12 yr old and the fridge 5, so it must have been dried and restarted before. Indeed it must have been primed when installed.
I cant tell the make of the pumps - one is a 3 ventricle 5 volt pulse type, the other looks more conventional 12 v diaphragm. The former is approx. 12 inches above waterline plane, the latter 18 inches. so not a mammoth uphill climb ....
any insight would be welcomed
thanks
J
thanks
J
