Primer for CAV Filter Head
Cav are a pain to deal with, if access is alright then it’s easy enough but try changing one at sea in an awkward spot and you will happy with a spin on, that and the amount of possible leak paths if you don’t get one of the seals in right, be changing mine at some point.
I got one of the asap primers which goes before the filter which allows you to prime the filter assy, on the output side it will not allow you to bleed the filter
