DrBob
Hi All, anyone out there give me some advice on changing my primary fuel filter? I search the forum records and picked up a lot of advice which helps me piece together my questions. On Saturday I did a full engine service on the boat (a 40 foot AWB with a Volvo MD2040). All went ok apart from the primary fuel filter.
First of all the top of the primary fuel filter is about 6 inches higher than the top of the diesel tank (which by the way is nearly full). Boat is around 18 months old and this was the first time I have changed this filter. The filter is a CAV type with a glass bowl at the bottom – new with the boat so the filter fitted was a Volvo type – and my replacement was a Volvo one. First thing was the nylon plug on the bottom was welded solid and snapped off leaving the thread in the base of the unit with a good seal- hence I could put it back together again.
After changing the filter over, I primed the system with the lift pump (also changed the secondary filter) although it took ages to “lift” all the fuel in to fill the primary filter. Engine started fine and runs ok. Problem is that the webasto heater (new last year) – which is fed from the second outlet on the top of the primary fuel filter – has not run properly despite turning on and off at least 10 times today (fault code saying not lighting hence almost certainly air in the feed pipe - between the filter and the heater pump?). It ran for 20 mins then stopped and has not started properly.
From previous threads I think what I need is a Racor type filter with an integral priming pump and that way I can bleed the air out of the feed to the heater pump. Any thoughts?
The CAV filter replacement was a pain and I will not look forward to doing that at Sea hence my interest in the Racor. First option is to get a conversion kit (from ASAP) but that wont have the priming pump – so is there another way to prime the heating system?
Do the Racor filter units come with multiple outputs on the top – I cant see from the ASAP site- and in the same orientaion as I have now to ease fitting?
Finally its difficult to see what the Racor system is. As a spin on filter, can you fill up the filter before spinning on so reducing the priming needed? Is then the filter a paper type element that fits into a housing – I cant work it out from the pictures on the site?
So to summarise
- I want to replace the current filter unit ‘cause I no longer have a drain valve and it was a pain to change the filter
- I need to be able to prime the heating circuit easier
- but I am not sure whether to get the conversion unit or a full unit
- And finaly is it worth getting a duel unit that can be switched at sea?
Any takers?
Dr Bob
So to summarise
Any takers?
Dr Bob
