solent clown
RIP
I have built in the past pressurised water systems for expedition trailers using plastic jerricans, a car type schrader valve assembly, and a skin fitting from a water butt which we found a reducer for at a plumbing supplies shop. primitive but it allowed the tank to be placed over the axle and low.
The idea came from old volkswagens that used to use a similar system for their screen wash, the pressure being provided from the spare tyre.
I was thinking about the potential for doing the same in the boat rebuild, partly for fun as I have everything laying about to do it, and partly as it would be one more thing that was not absolutely dependant upon electricity (or a foot lever that would break eventually) - And it would be essentially "free" I have both elecric air pump, and a high pressure stirrup pump.
I suppose in theory if you wanted to keep the water good without chemicals for a long time you could flood it with co2 instead of air the same as I do when home brewing.
Probably simpler to fit an electric pump eh?
