Pressurised water system
I had this with mine. I thought it was frost damage. It turned out to be an o ring that had hardened, and water was slowly seeping, causing the pump to repressurise every 15 or so minutes.
so went the boat on Thursday to work out side ,it was raining so tackled fault above dcided to fit an iso on the hot coming out of the hot water tank to narrow down it did not stop so further investigation ,I found water dripping out of the hot tap in the heads when open ,so decided a mixer tap must be passing ,I chose the galley tap as used most .Fitted an is to the cold to the tap turned off and the fault was cured , then opened to see if it leaked again but no ,still ok ,so I think the iso must have reduced the pressure to the tap and stopped it passing ,so we will see how it goes but pleased with a full days work in the dry
So found the problem today ,the pressure relief valve was passing ,I’ll get a new one to save trying to seat valve ,only 13 Quid, hope this helps some one some time.SS
