Peter
Just reinstated calorifier after temp repair and when checking system noted ot water tank accumulator had failed, no pressure and some water coming out of valve, so assuming diaghram holed. In conjunction with NRV on calorifier cold feed, ie no room for expansion, might have been a contributory cause of the calorifier failing. Something to check on periodically, pressure in accumulator.
Anyway, my question is why do i need a NRV on the cold feed to the hot water tank?. If there isn't one then any expansion from hot water tank could be taken up in the water system and by the pump accumulator.
Another question how long should a accumulator last for?
