pressure washers
doca
17 Aug 2004
Ireland
I am reading up on those gadgets with a view to purchasing one and cutting down elbow grease in cleaning car, patio, driveway ...and of course the boat. It looks as if something which produces around 150 bar (2200 psi)would be a good model but I wonder if any forumites used these things on boats, and is there a possibility of damaging gel coat, etc. ? My main concern is the burmese teak deck as I think I read somewhere that a turning a pressure washer on this material could be damaging. Any advice ?
bruce
26 May 2004
florida USA
also, over 1600 lbs will remove the 'crust' on brick surface and allow bricks to crumble much faster than normal on brick house. be sure to regrease parts after pressure cleaning.
mirabriani
17 Mar 2004
tite stops your nuts falling off
Quite right
When I was trail riding motorcycles , I found that pressure
washing meant the bike was nice and clean; but I was renewing
the various bearings much more frequently.
I would not be happy about using the very high pressure
washers on my boat, I'll stick to elbow grease
Regards Briani
StephenSails
1 Mar 2003
PSI on its own is more or less meaningless, you need to see how much water the thing will pump out per minute. There are lots of cheapo models claiming high PSI but with out a high water output they are not really any good for anything apart from cleaning the mildew of the patio.
heerenleed
13 Mar 2002
Netherlands
www.heerenleed.com
Use it all the time
on board. We have a very small one, it's very effecient to keep the boat clean. But, as others said, NEVER EVER clean your teak with it. It will destroy it. No problems on GRP, however. Even spray hoods and dodgers can be succesfuly cleaned with it...
Again: a small and cheap model does the trick for normal cleaning use. Also very effective to keep salt out of your bottle screws and head sail rollers...
cheers
capt_courageous
4 Jun 2004
Hampshire
Re: Use it all the time
Some people used a pressure washer on our pontoons. It seemed to open up the surface of the wood grain quite badly. They also became dangerously slippery. Dont even think about using them on teak.
Sans Bateau
19 Jan 2004
If you want a pressure washer to last any time at all make sure it has stainless steel pump parts, cheap models often use Ally parts, the minute you use any chemicals in them they corrode and are useless.
Pressure washers are great for removing the muck below the water line prior to antifoul, also a quick mid season blast off.
Its true a pressure washer at full pressure will destroy teak and canvas, however, open up the jet to more of a fan, and the pressure will be much reduced, this will allow you to remove green from both teak and canvas safely, without damage. HOWEVER be warned GO GENTLE!!!!! A fine jet will cut groves in wood!!!
doca
17 Aug 2004
Ireland
Thanks for all the advice. I got a 140 (max) bar / 7 litre per minute washer. SWMBO has ordered all paving, pathways, driveway, brickwork, roof tiles, windows, etc., etc. to be cleaned down first so it'll be some time before I put the gadget to use on the item I really got it for.
paulskent
24 May 2004
Deganwy Wales
As per previous warning, I have one of those Karcher home pressure jobbies. I used it to get all the green slimy stuff of our 2 year old Patio... Wasn't till it dried out that I realised I had taken the top layer of the preformed concrete stones and was down to the bits of composite stone and cement. It looked better when it was green.
Don't think I would take it anywhere near anything I cared for..
Be very carefull....
doca
17 Aug 2004
Ireland
If you do what Etap_owner says and open up the nozzle the water should be more in the form of a spray rather than a jet thereby removing less surface.
heerenleed
13 Mar 2002
Netherlands
www.heerenleed.com
Re: Can you use seawater?
I suppose you can. But I don't know if the machine would suck up the water by itself. Normally, you have the pressurised hose from the water tap connected to the washer.
I can imagine that internal parts would corrode sooner if you use salt water. I suppose you could cure that by using fresh water the last minute before you finish....
cheers
Bog standard B&Q special at less than 70 quid
About 100 bar, light enough to carry, power requirements don't trip marina breakers ..... does a fine job.
OK - maybe not cutting off some barnacles that are really stuck on .... but has served me well - in fact I'm on my second ......
As regards teak deck .... as long as beading and edges are secure - why not ??
Yes .... we regularly did on the coasters for washing down .... but always ran a good amount of fresh-water through after. BUT unless the pump has a good draw - note that freshwater use from garden hose is pressure TO the pump ... you will have to fill a container ABOVE the pump to ensure adequate supply to the machine. Some machines also have a pressure supply switch that if water is not supplied at pressure - the motor does not cut in .... (electric)
We found actually that sewater had a cutting ability - probably due to the salt / mineral content.
Honestly - yes - but fresh after to make sure the corrosive salt is removed.
TheBoatman
12 Nov 2002
Kent
Don't use it on the patio furniture, they come up sparkling but the pressure removes the top surface just as though they've been rubbed down with sandpaper.
