lazyliz
I had a weld fail on an oil feed pipe and need the part pressure tested. Basically there is an oil take off block on my Yanmar, which has pipe welded to it . The other end of the pipe has a 22 mm threaded connection. I need to blank off the block end, put 40 psi of pressure down from the threaded connection, to show that pressure (and therefore oil) is being lost through the weld failure and then complete a report. I live in North Wilts and is there anyone out there who can recomend a company.
