Kelpie
I'll shortly be rolling up my sleeves to do a major repaint of the topsides.
I read somewhere about Abranet sanding mesh (other brands available) which sounds brilliant stuff, especially where bulk removal of antifoul is required. I don't anticipate removing all of the antifoul, but as I am adding a boot top line I will at least need to remove the old eroding AF from that area.
The discs are sold in packs of either ten or 50... can anybody comment on how many I should expect to need, and what grits? It's supposed to last much longer than normal sanding discs.
I'll be taking most of the existing paint off and then applying undercoat and topcoat, so I'm guessing something fairly coarse (80?) initially, then something to smooth off the filler (120?) and then something to flatten off the undercoat (240? Or smoother?). I don't know if I'll end up sanding between topcoats, presumably depends on time and weather, but I guess that would need something like 320 grit.
As well as sanding, I wonder if I should be using any sort of degreaser, and/or tack cloths? The boat isn't undercover so most of the dust ought to blow away.
