beormakate
Active Member
We are using Coppercoat for the first time this year. The keel (iron encased in fibreglass) has been sanded back, taking off all old antifoul/epoxy primer and has revealed several places where the keel is exposed - where fibreglass has come off in pieces, holes in the resin where keel weeping, etc. I need to prep our keel before applying the Coppercoat.
We are going to give the underside 3 coats of Awlgrip Hullgard before Coppercoating (once faired and sanded inperfections). The reason for using this is that we are also Awlgripping the hull. Hullgard is a suitable base for Coppercoat.
Is it enough to sand/wire brush? back the exposed bits of the keel then glass over with West System (and mat where required), before fairing (with Awlfair) then Hullgard? Or does the keel need some kind of anti-rust/corrosive treatment (or even a layer of Hullgard before fibreglassing as it is anti-corrosive) before fibreglassing?
Any advice greatly appreciated as there is no point whacking all these pricey items onto the boat if what is underneath is slowly corroding away!
Thanks,
Katie
Thanks,
Katie
