Preparing for winter - will paraffin freeze in pipes?
Pete_M
30 Sep 2011
www.maidofmettle.wordpress.com
I've been trying to figure it out with the aid of google but freezing point doesn't seem to be a property that's listed - maybe there isn't really a single freezing point?
So, do I need to drain pipes (from main tank to pressure tank, and pressure tank to Taylors cooker) of the stuff over winter? The boat will be out of the water in Torpoint, Cornwall, with no heating.
aquaplane
16 Sep 2006
West Yorkshire
www.utilitywarehouse.co.uk
I doubt it.
Diesel waxes when it gets cold but I can't find anything to say that paraffin will.
If you are thinking about burst pipes, that's a wierd thing that water does, it's maximum density is 4°C so it's expanding as it freezes and keeps expanding, not a problem with most liquids.
Caer Urfa
28 Aug 2006
Shropshire
groups.yahoo.com
Hi Pete
I have had a Taylors 030 design oven for years and never had a problem with Paraffin freezing and I have been aboard in -14 C last winter.
When aboard in the winter I also use it as a heater with the oven door just set at 45 Degrees and all works fine.
Would I buy one? no, would I part with the one I have? No way!
Mike
VicS
13 Jul 2002
So, do I need to drain pipes (from main tank to pressure tank, and pressure tank to Taylors cooker) of the stuff over winter? The boat will be out of the water in Torpoint, Cornwall, with no heating.[
/QUOTE]
Best information I can find is that it starts to gel at around -20F !
As said it wont expand in the way water does so no problems which ever way you look at it
charles_reed
29 Jun 2001
It will in the Antarctic winter - 23 Kerosene does start waxing @ about -18C, my Finnish in-laws testify.
aquaplane
16 Sep 2006
West Yorkshire
Pete M,
If you want assurance, put some paraffin in a container and stick it in your domestic freezer to see if it freezes :D
As a chemist that just sounds so wrong, we never keep chemicals and food together, but thinking about it the chances of you coming to harm are slim to nonexistant. I wouldn't do it though, ingrained caution at work.
simon barefoot
9 May 2011
Cornwall
I did some pyrotechnic displays at the Eden Project last Christmas, which involved soaking 20' high puppets in paraffin and making them dance whilst they burned. On the coldest couple of nights the paraffin did start to turn slushy, but I'm not sure if this was due to it having some water/snow/ice contamination. However, it still seemed to burn ok, the only times we had problems was when the wick material got wet.
pappaecho
13 Oct 2004
S. Hampshire
Diesel starts to form a wax at -15-16 degrees C. Paraffin lower still. If the inside of you boat gets anywhere near that by the sea in Torquay we all have all got serious problems...
Even if the system waxes up it will not burst pipes like water, and will naturally re dissolve as soon as the temperatures rise.
Put simply dont worry about it
Scotty_Tradewind
31 Oct 2005
Me: South Oxfordshire. Boat, Galicia NW Spain
Not likley to freeze. It can be added to diesel fuel in cold weather tomake it flow .
I remember years back, (whenliving near Benson S.Oxon, one of the coldest places in the south) my neighbour was a coach driver and regularly added a small amount of paraffin to the tank in the severest weather. I believe it can also harm the engine??
Hasn't diesel at the pump now got additives that put its waxing at a lower temperature?
However as/charles...... not seen too many -23deg temp's lately.
alan_d
15 Mar 2002
Scotland
Much the same as your bottle of olive oil (except it doesn't need to be anything like as cold to turn waxy).
macd
25 Jan 2004
Bricks & mortar: Italy. Boat: Aegean
I have a Wallas paraffin heater (works on similar principles to Eberspacher), made in Finland (where the penguins come from, according to Mr Reed?). The handbook suggests adding a small amount of isopropyl alcohol to the fuel if waxing becomes a problem in extreme cold. The UK importer suggests this is never necessary in UK conditions.
So:
1. as other posts have explained, it won't damage the pipes even if were to freeze, which it won't.
2. It will almost certainly continue to work at UK winter temperatures.
Neither of these worries me unduly in my present location.
