mm1
A while ago now I posted about changing from original volvo DPs to the Power Tec ones.
Here are the results
P T props seem stronger, the paint is staying on longer! 18months now & only cavitation burns (Volvo paint would peel off at this point)
Props are like for like & the vessel speed & engine revs are the same as before.
If I remember correctly the new props were about £75 per set cheaper
Someone on the forum said they work straight out of the box! They don't as there are 2 washers that need to be removed from old props & put on new, only a small point but crucial.
So all in all a good result so far.
Hope this helps anyone thinking of changing.
