PabloPicasso
I know changing masthead tricolour incandescent bulb for an equivalent led will save power, but by how much?
The NASA tricolour uses 200ma.
The Aquasignal uses a 25 watt bulb which is roughly 2 amps.
On that basis a LED is one tenth.
Or you could just run the engine for an hour in the middle of the night. This would also get the fridge cold again if you have one. I am looking for am LED fridge.!!!Ok so I can run the tri color overnight on less than a tenth of the power. Very useful on a passage.
So at night sailing I will have to continuosly power tricolour, depth sounder, compass light (is there an led replacement for that I wonder)', VHF, plotter, and autohelm. I guess the VHF could be switched off
Thanks for the replies. I'll replace the masthead bulb next time I have to go up
The replacement LED "bulb" ( similar if not identical to the one in my earlier post) for my Aquasignal tricolour came with a replacemen holder so that the coloured sectors of the LED could be correctly aligned with the lens ... it would have been nowhere near, over 90° out, if simply plugged into the existing holder.
( It is an ECS one bought from Force 4)
It would not have been a job that could easily have been done at the mast top. It was necessary to remove the ( quickfit type) lantern and work on it on the cabin table. I also had to power up the unit to determine exactly which LEDs were which colour!
Pics of LED unit and new holder:
Old and new holders
Old holder before removal
But why not just a warm white led like this?
http://www.boatlamps.co.uk/contents/en-uk/d66.html#p73
