Graham376
Have had a problem with fresh water pump kicking in immediately when tap turned on as opposed to after a cupful. No tap on, no pumping so, not a leak situation. Checked the (membrane) pressure vessel, no pressure so pumped it up again. After a couple of days, no pressure again so, changed the schrader valve, which mad no difference so, have just replaced it with same type Zilmet Z200. This comes pre-charged to 3.5 bar, Flojet water pump is 2.2 bar. What pressure should the vessel be charged to? Easy to adjust via valve and bike pump.
