Post deleted by danfoley
halcyon
20 Apr 2002
Cornwall
Re: Supplier of Contact Breakers
Try ETA, they do a push on / pull off, but from memory they are larger, they also do a 110 seieries, which is 19 mm square, and push / push off. Airpac do some push on / pull off, ETA also do a rocker switch type, think Carlingswitch have some in there range, Hawco list a cheap rocker switch circuit breaker, stock one type, but not the other.
They are not that cheap, around £8 each, except Hawco ones.
Brian
john_morris_uk
3 Jul 2002
At sea somewhere.
I'm pretty sure I bought some from Merlin last year. I also think one of the local chandlers stocks them here in Plymouth.
Having said that what current trip do you need? I have a load of spare ones in my spares kit...
Pierrot
N/A
16 Mar 2005
Try rswww.com - they are first choice for anything vaguely electrical.
I've used them for Circuit Breakers, Tinned Cable, Voltmeters, Deck Glands, etc all at less than half what you would pay from a marine supplier.
tross
19 Aug 2003
Lymington
I am not sure of the price at RS but I would take a look at a US company called digikey www.digikey.com I researched this subject sometime ago for my own use. They are normally very good - I use them for small quanitity prototype work for my business and you can use a local 0800 number.
LittleShip
21 Jul 2003
In the water .... most of the year!!
http://www.power-store.com/
Try these they have push button circuit breakers.
Check under electrical ditribution then circuit breakers.
Tom
tome
28 Mar 2002
kprick
Brian
Agree it sounds like an ETA circuit breaker, these are IEC 60934 approved and commonly used in boats and ships. There are quite a range to chose from, but something like the one below is very common.
They are available from:
Furneaux Riddall & Co Ltd
Alchorne Place
Portsmouth
Hampshire
England PO3 5PA
Tel: 023 9266 8624
Fax: 023 9266 8625
