Post deleted by danfoley
Talbot
23 Aug 2003
Brighton, UK
Re: Seized Stanchions
The only way to free it that I know off is to heat it up until just before it melts ! worked for several items for me over the years, but not really a starter if you dont want to remove stanchion base from deck! I have tried all sorts of other things and none of them really worked as well as the heat and bashing with a big stick.
boatless
1 Mar 2004
Cut it off flush with the socket, drill down the wall of the remaining tube in a couple of places and then break it at the weak points?
<hr width=100% size=1>my opinion is complete rubbish, probably.
Benbow
11 Jan 2004
How about this. You actually want to shrink the stanchion, heating will expand it*.
In the past in slightly similar situations I have poured liquid nitrogen onto the inner piece with instant sucess. However I would not recommend this unless you can turn your boat upside down and dip the end of the stanchion into the LN2 ! But what about packing around the stanchion with solid dry ice, leave to get as cold as you can and then trying to turn it out ? Dry ice is readily available.**
Maybe worth a try - it will work in 5 minutes or not at all.
*Although I have to say that heating does often work, presumably because the relative movement as it expands breaks the join.
** add boring comments about potential hazards if you hold dry ice on bare skin or shut yourself in a small room with it.
tome
28 Mar 2002
kprick
www.google.co.uk
Brian
Never tried this, but am told that soaking the joint in Coca-Cola over several days can break down the corrosive powder and free the stanchion. Be interested to hear if it actually works!
Tom
broadcaster
6 Feb 2004
Hi,
Just a suggestion which I have never done myself, but have you tried grinding a slot in the stanchion using a Dremel tool with a long slim grinding tool. You could probably try and pry it out.
Andy
VictorII
4 Feb 2003
Belgium
home.scarlet.be
None of the comments I've ever seen on this subject seem to salvage the base. I'm afraid I also drilled through the bolts and destroyed the base while removing a stanchion last year. Usually the bolts are stainless so they are drilled through much slower than the aluminium. This always destroys the latter. If you want to keep the rail in one piece, destroy the base. But since the stanchion is already dead, perhaps some other method might work.
Moodyowners.org.uk have a full explanation of the process but it seems to be behind a userID now.
DanTribe
8 Jan 2002
Essex
I had this problem last year & tried most of the above suggestions [never thought of the nitrogen trick].
Final answer, after several weeks, was an angle grinder & all new bases.
It was hard to believe that the things could get so gunged up.
Dan
jerryat
20 Mar 2004
Nr Plymouth
Hi mriley!
It's extemely simple. Each year, at laying up, remove the stanchions, smear with Blakes seacock grease (or similar waterproof type) smear inside of bases and re-assemble. I have done this without fail for the last fifteen years on my current boat (and on previous boats as well) and have NEVER failed to slide them out at any time.
Hope this helps.
Good sailing!
bruce
26 May 2004
florida USA
you could cut the stantion at the base, insert hacksaw blade into the old tube, reattach handle and saw through the stantion wall, taking a punch/screwdriver and separate tubing from base. may take 2 cuts. where in fla?
jimi
19 Dec 2001
St Neots
Attach dodgers to them and then come sailing with me again .. we'll soon get the buggers loose .. jist remember to tie yer glasses tae yer heid this time!
DanTribe
8 Jan 2002
Essex
In my case I replaced the aluminium stanchions & bases with stainless ones
Dan
Birdseye
9 Mar 2003
s e wales
If you have aluminium stanchions in stainless bases then you will be in deep do-do corrosion wise. The formation of the aluminium oxide (which is bulkier than the aluminium and therefore causes the joint to seize up) will be even faster.
<hr width=100% size=1>this post is a personal opinion, and you should not base your actions on it.
