BobE
I'm now running the Neptune navigator passage planning program which allows me to adjust for tidal streams both in advance and DURING the trip. (coupled to the GPS of course)..
It's only failing is the lack of chart detail so I'm also trying the chart prog used by "Lady in bed" (You know who that is!!)
What I need to do is to couple the GPS to both the programmes simultaneously..
My GPS is connected through the small 9pin plug (Com 1 ??) ( Serial Port?)on the back of the laptop. It will not allow both programs to receive the NMEA output at the same time..
Do I splt the lead and plug into one of the female sockets on the laptop? The one with 25 connections (? Serial Port?) or even one of the multi strip connections or set up the "Docking station"
Maybe I should just get a dedicated plotter... But the current stuff seems potentially quite adequate if I can run both progs. at the same time..
Come on you electronic gurus, sort it out for me pleeeeze!!!!!
Cheers Bob E..
Cheers Bob E..
