pop rivits
searover
3 Feb 2004
Hi all, Iwant to pop rivit my radome bracket to the mast, i can only get a certain lenghth and no longer rivit ...1"end How much would you think is safe minimum protruding into mast as the bracket is quite thick ???????????? Thanks in advance Roy
searover
3 Feb 2004
Hi i wasnt sure if the mast would be strong enough to hold the weight of radome if i drilled for bolts or self tappers, with the mast beeing ally what would be the strogest??
john_morris_uk
3 Jul 2002
At sea somewhere.
Ask a rigger. Not sure where you are relative to a local rigger, but the length of the rivet is determined by the thickness of the mast and the thickness of the bracket with the size of the hole being taken into account as well. A rigger will not only be able to advixe you on the correct ones, but sell you a handful of the correct monel rivets to do the job. They aren't cheap - but it will only be a couple of pounds to get the correct ones.
You then need to borrow a big rivet gun...
In Plymouth I know where to go, but not sure where you would go in Lancashire!
William_H
28 Jul 2003
West Australia
Agree if you can't get a powerfull rivet gun then go for drill and tap the mast for suitable sized bolts. Then use duralac on the thread to prevent corrosion. A tap is quite cheap to buy. olewill
srp
10 May 2006
Barnard Castle, Durham
Re: pop rivets
No one has actually answered your question yet! There was another recent thread here on this topic, and the general consensus was that the rivet length should protrude by at least 1 x the diameter. Also make sure the rivet is the correct size for the hole. If you decide to tap a hole instead just use A4 stainless machine screws.
In either case, screws or rivets, you'll need to use Duralac, as others have suggested.
searover
3 Feb 2004
Re: pop rivets
Hi thanks for that, that gives me something to work to, i mite even use bolts as you say. thanks to everyone for advice kind regards Roy.....
William_H
28 Jul 2003
West Australia
High Topcat I have never seen or heard of Monel screws. Maybe because I live ina backwater? Monel pop rivetts yes. I havee found screws with duralac seem fine in Al. olewill
cliff
15 Apr 2004
various
Re: pop rivets
High Topcat I have never seen or heard of Monel screws. Maybe because I live ina backwater? Monel pop <u>rivetts</u> yes. I havee found screws with duralac seem fine in Al. olewill
[/ QUOTE ]Here for a small list of suppliers. or there is "MacRae's Blue Book" which lists more suppliers. Guess maybe you do live in a backwater. /forums/images/graemlins/grin.gif
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
William_H
28 Jul 2003
West Australia
Re: pop rivets
Thanks Cliff my education is expanding with this forum all the time.
Not just in a backwater (far SW corner of Indian Ocean) but not often buying bolts etc anyway. My chandlers have SS screws tass all. olewill
