Durcott
Hi folks,
I posted a while back about poor VHF radio reception. Some of you gave your opinions, so I thought I'd report back what I found. There's another question at the end.
I found a reasonable SWR meter, complete with a dummy load, on EBay as suggested. The transmitter worked perfectly straight into the dummy load, but I measured total reflection from the cable between the radio and mast connector (N type socket). [Yes I had moved the load /forums/images/graemlins/wink.gif]
The cable looked like a fairly cheap RG058 clone. The plug at the radio end hadn't been soldered on properly, so I thought I'd 'fix' it.
To cut a long story - 'black wire rot' had got into the cable at least 2' into it and probably more. The centre conductor was brittle and impossible to work, and the braid, though tinned, was equally fragile like rotted cotton.
So there you go. No external indication, but internally ruined and useless.
Well - I can rewire with UR67 say, but I'd never get that up the mast. Is there anything I can do to avoid using relatively lossy RG58 inside the mast?
Jeff
Jeff
