kalindi
The previous post generated two points of view, one that a compression test is a wate of time and the other that it generates useful information. But as I requested it and it has been done then there is no going back. The results were 310, 400, 390,390 (converted from bar)> The french mechanic thinks that this is not a major problem. The injector in the offending cylinder was not working correctly and has been put right. His proposal is to put it back together, give it a good blast and see what happens. So as that corresponds to the advice given from the last post I will give it a go. Thanks for eveyones input.
