Poor connection in old copper wiring
careymack
New Member
9 Feb 2005
A lot of my wiring is original plain copper and built into the boat. Where it exits there is often only a short length exposed and this is often heavily oxidised (black on the surface of the copper) Can any bright spark advise me if it is possible to get solder to take? Maybe by tinning it using Bakers fdluid?
If it's black it's most likely well past it , best bet is to renew completely with tinned copper strand , but others may offer an alternative idea
Many thanks for that. I fear you may be right. I'v replaced most of the wiring with tinned but the embedded ones are a pain. I'm just hoping that I might find a way to get get a reasonable connection.
What others have said here is quite correct, but before you get involved in a major re-wire try cleaning the black, which might only be on the surface, with a gentle application of Brasso or similar. It is also quite likely that the covered parts are clean.
