Poole Lifting Bridge - Air draught?
[2068]
19 Sep 2002
Hi,
I was considering going to Cobbs Quay marina at some point, but the Poole lifting bridge is in the way. I know there is an air draught indicator, but typically, what is the range of air draught?
Would an S28 fit underneath?
dv.
Gulp, Thanks for that.
Will aim for opening times, then /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
I am not saying they couldnt get under, but I think your boat may be too big. It has boards on the side that sort of block it. (not your boat of course /forums/images/graemlins/grin.gif) Anything with a cabin probably gets stuck.
You could ask them, apparently they have installed a display
Poole Bridge
Good luck
D
Hi - we were at Cobbs for 3 yrs with our S28 and we never managed the bridge - no hope with the nav gear although our goal posts were higher than normal for some reason ! Do not risk it - a friend risked it with his Bavaria 30 ( brand new) and had a smashing time - he was a local as well.
Air draught of S28 to top of light is 3.23m so you can go through the bridge at 1.1m tide height, to the top of S28 arch not inc light is 2.7m so with light through the centre of beams on tide height of 1.7m the boat will go through
Just be sure that the water is smooth and you're not going to bounce around in some elses wake as you go through though....
i've been under many times,
rule is if you can see the 3rd horzontal beam you can get thru but must have light tower centred thru the gaps
i do it quite a bit
jetski passed me once and his wash put me off, scraped the spot light, no damage but cant get blue bridge paint of top of the light !
there used to be chap with windy who would drift thru on the tide sidways as his whole radar arch passed thru the beams !
go for it
I can vouch for that, he is my next door boat neighbour.
As mentioned above, practise going under the bridge when the 3 beams under the bridge are showing and you will be OK. This is for a standard light set up not one with radar as Castanet had, there are a bit taller. Once you get use to it it's OK. I have been going under (sounds a bit rude!!) for the pass 5 years and the bridge is still standing.
Agree about the cuddy boats hanging back but that's another story - must not go there - quick get my flame resistent suit.
