bromleybysea
This looks like a good buy and would solve the holding tank problem when cruising in Holland: http://www.lidl.co.uk/cps/rde/xchg/lidl_uk/hs.xsl/index_20244.htm
Mind you, there is the problem of where do you put the thing.... On my little boat I can’t think of anywhere it could reasonably reside and still be useable with any degree of decorum unless I unbolt the Lavac or perch it on top with a suitable step-up, but head-room would be pretty limited. Does the affluent tank detach for disposal, discreetly covered by a napkin like the old starchy nurses used to employ in hospitals when they emptied the bed-pans? Or do you have to lug the whole kit and caboodle up the pontoon, to the general amusement of the assembled populace? And why do you need a different fluid for “solid” and “liquid” waste. What happens if you are not sure before you “go”?
Getting old is forgetting to zip-up after you’ve had a pee. Getting really old is forgetting to un-zip first.
