polyurethane foam and fumes and DVDs/camera film
ybwuser
28 Dec 2008
uk
I made a box of ply and used epoxy and silica to make glue.
To be doubly sure there were no gaps I used a bead of foam inside (wanted it air tight)
I store dvd's and cds and photos and video tapes - all very sentimental and not replaceable.
I opened it and the fumes sent me reeling.
Could these fumes damage the media stored within - google has not helped so far?
There has to be an element of guess-work here, as I certainly don't have any experience of this.
Epoxy is completely inert when cured, more so than many other materials used for storage. No problem there.
Polyurethane foam takes a long time to fully cure, during with time small amounts of isocyanate may be released, probably toluol di-isocyanate with DIY foams.
I can't see tdi affecting the discs but no idea what it might do to photos and tapes.
You have two options - remove the foam and add a bit more epoxy and silica to ensure the air-tightness. Cure warm if you can, just putting a light bulb in the box is a good method. Alternatively you could just leave the foamed box for a longer time, try blowing a hot air gun into it to heat and disperse gases. I would pick the former one, as the foam is not contributing to the functionality of the box.
Presumably your box has an opening lid, in which case it is unlikely to be air-tight.
Better protection would be provided by buying some inexpensive plastic food storage boxes instead. These are probably as water-tight and air-tight as you are likely to get. It would be a good idea to pack a dessicant (e.g. silica gel) with items that need a dry atmosphere to avoid condensation forming in the boxes, and wrap photos etc. in acid-free tissue paper if they are really valuable. Museum quality archiving materials and advice are available if you google.
