laika
Previously I've managed to borrow polishers (being happy with what I got, whatever) and do a lot manually (very time consuming with 12 and a bit metres to do). Not now being able to blag someone else's I've decided to buy my own and after forum advice have decided on the silverline.I'm now faced with the array of different sponges to decide from: I confess to not knowing whether I should use "soft" or "firm" as previously I just used what was available. So what pads/sponges/bonnets does the forum recommend for the different stages of making my gelcoat look shiny?
Also there are two very similar silverlines:
the 264569 goes down to 300rpm
the 129659 goes down to 600rpm, is a tenner more, 100g lighter (not much when it still weighs 3.8Kg) but (I believe) has a constant speed thing whereby it tries to maintain speed when you press harder.
Anyone bought one and regret not buying the other? Not promising that silverline didn't respond to my customer query form asking what the difference was between them (before I'd done a bit more research)
