Polishing stainless steel after fabrication
sarabande
6 May 2005
How practical is it to polish to a reasonably decent shine by hand, pls ?
I have various linishing wheels for the variable speed polisher, but there are many nooks and crannies near welds and crossovers that will look out of place if I can't make them shiny.
What kit (abrasives, rouges, etc) will I need ?
I'm sure you would get a decent job without too much trouble but it would depend a lot on what tools you have. I've done lots of polishing work as the metal used in fabrication is normally satin finish.
If you have lots of nooks and crannies a dremel would be handy. (I use a die grinder but then I have a 15 cu ft compressor)Screenshot_2020-01-05 angle grinder polishing wheel eBay.pngScreenshot_2020-01-05 ss polishing eBay.png
Screenshot_2020-01-05 123pcs Felt Pad Set Mirror Polished Polishing Buffing Pad Clean Wheels e...png
Depends what state it's in to start with.
You may want to start with a file!
Very often, working down through a few grades of w&D paper is a good method if you don't have a high powered bench polisher.
I have a stitched fabric wheel on a standard bench grinder for finishing off, using a blue soap compound.
Seems OK for most things.
Felt heads on a dremel are good for intricate bits.
Floppy buffing wheel (no backing) that spins to shape at high rpm, and a big stick of polishing compound. It'll take on any shape and go around corners. That's how the very experienced stainless manufacturer did the welds on my stern arch and they're at all kinds of tight angles - the floppy disc just gets right in there and does the job. Makes an epic mess in the workshop, but it's quick and thorough.
