Phoenix of Hamble
i've been 'umming and arring' for some time about getting a pole for the boat..... not because I want a kite... I don't... but because i'd like something to use to pole out the genny when deep downwind (a la whisker pole), but more crucially, so that i've got the neccessary pole on board to create an emergency steering system should it be needed...
So.... if it was just a whisker pole I was after, i'd look towards a telescopic set up.... but with the emeregncy steering factored in, that looks less appealing....
Which brings me (eventually) around to the question(s)...
Firstly, what length should the pole be?.... J measures 4.1m on my boat, and i've always worked on a spinny pole being 1.25J, and that makes 5.2m.... which seems awfully long for poling out the genny.... its a light wind thing only, so suspect it should be a bit shorter... thoughts?
Secondly, pole diameter... again, for a light wind whisker pole, not so large, but for emergency steering, a bit heavier might be sensible.... I was thinking something around 70mm, with commensurate wall thickness.... thoughts?
Lats, but not least.... anyone got one that meets these specs that they want to give away? /forums/images/graemlins/grin.gif
