Polarity checker
lydiamight
9 Feb 2004
North West Kent
After reading some of the various threads about incorrect/reversed mains polarity I would like to be able to check mine. I have a digital mains multimeter and a healthy regard for the dangers of 240volts----how do I actually go about checking if my boat and/or its power supply is wired up correctly?
Vara
20 Feb 2004
Canterbury/Dover
Any electrical supplies company.Will sell you a plug in tester.
3 Pin plug with little LEDs on the back,plug in and it tells you whether all is well(or not).
Mine was £14.99 from CEF,but B&Q do them.
Just a thought I 'm not sufficiently techie to know whether a galvanic isolator will effect earth reading?
Have used mine in most marinas South coast UK and North coast France and have not detected any problems.
<hr width=100% size=1>If it can't be fixed with a lump hammer dont fit it!
Bergman
27 Nov 2002
What you do is measure the voltage between each terminal and earth.
The "live" terminal will show about 230V
The "neutral" terminal will show somewhere between 0 and 10V
If you get 0V on each terminal then check earth connection.
Be careful, live side of mains doesn't give many 2nd chances
TonyS
23 Feb 2003
Southampton, UK
I am not an electrical expert but I would assume that the live line is at approximately 240 volts to earth and the neutral only a few volts - which you can determine with your mains tester.
Or am I wrong?
<hr width=100% size=1>Tony
Talbot
23 Aug 2003
Brighton, UK
Caravan shop should be able to sell you a plug in device that will check the supply coming into the boat. You are responsible for making sure your wiring in the boat is correct.
gosh
10 Jan 2004
UK (Christchurch)
My shore supply comes in through into two 13 amp sockets. One is wired correctly and the other with reverse polarity i.e.live is connected to negative terminal. When I plug into shore power I check with a neon tester which socket is putting out the correct polarity and then use that socket to connect to the boat 240V circuit. I use this frequestly in France where they seem to be very cavalier about polarity. A polarity check and polarity changeover switch costs about £150.
Hope that helps.
LittleShip
21 Jul 2003
In the water .... most of the year!!
This is all you need
<A target="_blank" HREF=http://www.tlc-direct.co.uk/Main_Index/Necessities_Index/Ring_Main_Tester/>http://www.tlc-direct.co.uk/Main_Index/Necessities_Index/Ring_Main_Tester/</A>
I wish I'd been born rich instead of good looking ?
