Mickster1969
New Member
Hi there,
We bought a 17' Magregor Venture a short time ago. It is a fibreglass hull with wooden seating and deck inside. I pulled up some punky panels in the bow today and found the wood underneath was completely gone and rotted away entirely in places so I have to replace it all. I have a few questions which I would greatly appreciate some help with as I can't seem to find good answers on the net.
1. The bulkhead spaces were all filled with polystyrene (some completely sodden) but I don't believe there would have been enough flotation from these to keep the boat above water (if so it would be bow up I believe as there are no blocks in the stern space). Is it worth putting fresh polystyrene in place?
2. I need to replace three ribs/bulkheads that support the forward berth type area (think that is what the semi-circular port to starboard supports are called?) and I can see that they will need to be cut to shape and then glassed to the hull. Would I glass the whole rib/bulkhead or just the section next to the hull? How many layers are generally advised for this? Also is it not worth leaving a hole between each bulkhead at the centreline to allow any ingress of water to run aft?
Any help you can give or even link to a good website or utube video would be greatly appreciated!
