Tim Good
I have a Thermo 90 webasto heater that heats water and pumps it round the boat to heater matrix units that then blow hot air and also heater the calorifier.
At the same time the engine cooling loop goes to the calorifier as with many boats.
Is there any reason I couldn't rig the webasto water pulmbing in parallel with the engine cooling plumbing (as it goes to the calorifier) so that i could run the heating whilst the engine is on and without running the webasto. i.e. hot water would run around the system but the webasto would just be turned off.
