Please can you identify this Honda Fuel fitting from these photos?
Durcott
10 Jul 2006
East Cowes, Isle of Wight
Hi Folks,
I hope you can see the pictures at http://s100.beta.photobucket.com/user/durcott/library/ (Hope this works :o )
This should be 4 views of a fuel fitting, on an old (ancient) Honda BF9.9a.
This fitting is different to the original, and I'm guessing it is still a Honda part as it 'fits' the motor.
Now - some oik has walked off with my fuel tank - Gee thanks mate :mad: - and I need to get a fuel line made up.
Which part will mate with the fitting in the photos?
Do you happen to know?
Kind regards
Jeff
Hi Nik,
well as I say - it's not the original fitting. I had to change the fuel line when a service guy suggested swapping out the original.
The serial plate detail got melted off with anti foul - yeh! Thanks previous owner!!!!!!! I think there are stampings dotted around which have been used to zero in on the exact model, but in this particular case, even that is not much help.
Cheers
Jeff
Ah right, Damn I didn't read properly, apologies!
I'll take a peek through the schematics if I get a quiet moment today and see if I can find anything on a BF9.9a variant which might appear to match it...
Hi Folks,
Kind regards
Jeff
If you think it is a Honda part then look at the Honda fuel line connectors in the Sierra catalogue http://www.marineengine.com/parts/s...arineengine.com/parts/sierra_marine/index.htm
If not a Honda part then look more widely at fuel line connectors but i think I can see it among the Honda connectors with to alternative fuel line fittings
Also look at the parts list on the Honda parts website ... but you will have to look engine model by engine model so could be tedious
Alittle easier than the Honda parts list may be the parts lists at Boats.net http://www.boats.net/parts/search/Honda/Outboard Engine/parts.html
( no pictures too small)
If you cannot find it you will have to buy both halves of a new connector.
This I think is the half you have
18-80407 - CONNECTOR
Replaces: 17710-ZW9-033
5/16 with interlocking post
Fits: BF8-BF130 (2003)
It mate with two alternative connectors
18-80403 - FUEL CONN.
18-80403 Fuel Connector
Part Number
18-80403
Manufacturer
Sierra Marine
or
18-80408 - FUEL CONN.,HONDA
18-80408 Fuel Connector
Part Number
18-80408
Manufacturer
Sierra Marine
You should be able to find Honda parts numbers in the list for a 2003 model http://www.boats.net/parts/search/H...SHIFT SHAFT (HANDLE SPECIFICATION)/parts.html
this could be the one.
Part Number
18-80403
Manufacturer
Sierra Marine
