Daydream believer
If you test the epirb as much as some suggest how long will the battery last
But you will have done that test with it static and optimally aligned for the SATs. Move 200nm and get in the water and see how long it takes.
My McMurdo says in the instructions, ............... why not just follow the instructions
They serve two different, but related purposes. Which you choose depends on what you see as the greatest risk. Flares are for attracting attention visually and perhaps helping rescuers home in on you. EPIRBs are to signal a boat is requiring assistance and once set off does not need any human attention, a PLB locates the position of an individual and needs to be activated and kept out of the water. Neither can be "seen" by other people or vessels, but a remote observer and neither are instant. A DSC radio performs a similar function to an EPIRB but range limited by VHF range. However will be heard instantly by both other vessels (assuming their radio is on) and shoreside observers who can arrange assistance.
So, for coastal cruising a DSC is most important, out of VHF range then an EPIRB or PLB (but recognising they are not "instant"). Flares of less importance given the other methods available, but have been proved to be useful in the past.
There is lobbying to get flares removed from compulsory list on boats that have compulsory requirements on the basis that other methods do everything a flare can. Not everybody agrees.
I'd agree totally that a properly set-up DSC, connected to a GPS signal and with a registered MMSI is probably the most anyone
I'd agree totally that a properly set-up DSC, connected to a GPS signal and with a registered MMSI is probably the most anyone needs.
worn round neck when single handed
Indeed, if one of the 'man-overboard' alarms (which trigger if the base unit LOOSES contact with the wearer) could be interfaced to a DSC radio this could be an excellent solution for single-handers when within VHF range. In theory the DSC alert could also contain the relevant information that a single-hander was overboard. Sadly any such device would not be 'legal' under present rules.
I can see this wasting a lot of rescue resources. What's the issue with just using a PLB, this scenario is exactly what they are for!
Yes, I can see your point if on a crewed yacht an alert was triggered even though the MOB was easily recovered by the crew. I was primarily thinking about single-handers, and the (alleged) considerable delay before a PLB alert is acted upon. No ideal solution![]()
