Norman_E
I need to make a larger instrument pod to replace one made of fairly thin plastic. My plan is to build it from plastic sheet material 6 or 8 mm thick, with the edges made from much thicker material, so that I can round all the corners with a router.
I have found a supplier here with a choice of nylon, delrin & acetal materials. I need something that will machine, and can be welded with a suitable solvent.
Does anyone know what I should choose, and what solvent will weld it.
