mickshep
Our boat is fitted with a Hydromarin hydraulic system driven by a 12hp diesel. The prop shaft runs inside a stainless steel tube that has what appears to be a large nylon looking bung in the outboard end, through which the shaft runs. This appears to be the cutlass bearing and is worn to the point that the shaft can be moved about 2mm from side to side, Firstly I am assuming that the 2mm of play is excessive, If so what plastic should I be looking for to have a new water lubricated 'Bung'/Cutlass machined up from, A supplier would be handy too, Cheers all, Mike,
