plastic skin fittings.
viago
24 Jan 2012
plymouth
any opinions about these things. i understand there to be problems with brass ones and want to replace the cockpit drains which are a bit below the water line.
i normally murder up skin fittings with a decent pair of stilsons but fear such enthusiasm will just strip the thread on the plastic variety. how would one know when enough is enough?
oldbilbo
17 Jan 2012
West country
I'm advised that the 'tight-th' needed is just enough to ensure a watertight seal by compression of the sealing compound used.... That's considered 'hand-tight' when first installed, then a day later when the Sika-gunk ( ! ) has cured, another half-turn to provide compression pressure.
Further tightening only increases the load on the through-hull's threads, so that the potential for damage is increased.
Or so I'm told.....
