Pitting on Jabsco face plate - is it electrolysis?
Rivers & creeks
23 Nov 2004
Norfolk
I looked at the inside of the face plate on the Jabsco raw water pump on my new to me engine - it was a horrible mess, probably a lot of sediment in the water where it was used but worryingly there was a pitted area about 3mm across and 2mm deep and other smaller nicks, looked very much like corrosion - maybe from electrolysis? Is that possible and if so where else in the engine should I be looking for potential electrolysis issues? The engine was started and ran well just before delivery to me. It's a Mermaid J444 Dieselmax that doesn't have an engine anode.
Possibly a form of crevice corrosion / dezincification. The corrosion goes mad in the absence of oxygen due to the sealing effect of the rubber ones against the cover.
If so the problem is likely just with the pump.
What is the material ?
Can you post a photo.
It's a standard Jabsco pump so I gues bronze. I forgot to take a photo of it :( I guess from what you said I should examine the rest of the pump housing inside. I replaced the face plate with an excellent Speedseal. I worried that there had been more widespread corrosion - are you saying it might just have been the pump insides?
Most likely brass rather than bronze, and sounds like simple de-zincification. I would remove the impeller and see if the housing periphery is OK, or whether there are distinct lines of pitting where the lobes had sat unmoved for an extended period.
Yes, that is my experience. Not certain whether Jabsco and Johnson fit the same plates but several that I have inspected were brass and had suffered dezincification. It is easy to differentiate brass and bronze by colour. Compare with a plumbing compression fitting, which will be brass. Bronze is very pink by comparison ('red brass' in American)
Thank you. So dezincification but most likely only localised electrolysis rather than a wider problem.
