moonshine
On removal of a vent hose from the stub of a stainless steel holding tank I found that the end of the stub had been 'eaten' away. I also found surface pitting for 10mm from the end of the stub where the hose was clamped. Tank is only 4 years old, and to my knowledge the hose has not be removed before !? The boat builder had used a very rubbery adhesive on the stub, (Sikaflex product ?), where there was adhesion there does not seems to be any corrosion, but the downside was this made disassembly only possible by cutting the hose.
Reading up on the subject, the problem seems to be exclusion of oxygen from the surface of the SS. Difficult to see how this can be overcome with a hose clamped on the stub ?
Do the experts have any suggestions for a product, (apart from Sikaflex), that could be applied to the surface before assembling the hose and would stop/slow corrosion ?
Moonshine
Moonshine
