Pigtail eye bolt (or similar): where to buy?
chal
13 Jul 2010
Valentia Island, Kerry
I'm looking for some sort of eye bolt that allows the eye to be disassembled so that I can attach it to something (an eye at the end of a staysail boom). Obviously a shackle would do this but it allows a lot of forward/backward movement and I'd prefer to omit it if possible.
I'm sure I have seen, somewhere, an eye bolt where the eye part consisted of two semicircles bolted together, but I can't find one and I don't know what they are called (if there is a specific name) to search online. I found a pigtail eye which would do the trick perfectly well but the only places I've found online that sell them are Chinese factories with minimum order of 1000. I only want one!
Any ideas where I might get anything that would do this job? Pref in A4 stainless.
Thanks for the suggestions, but: the alibaba one I'd already seen and I think it's one of those where you need to order thousands (though I suppose I could request the free sample!), and the ebay one has a closed eye so I'd need to use a shackle with that one.
Hydrozoan: thanks for the links - the hook eyebolt looks like it would do the job and at least you can buy just one of them.
prv: a U-bolt would work in the sense that I could capture the eye on the end of the boom. However, at the moment the only possible attachment point is a fairly hefty eye bolt, for which a hole already exists in a samson post: to use a U-bolt I'd have to drill another hole which I'd be reluctant to do - I have considered the option but thought I'd see if I could find a direct single-bolt substitute for the current eye bolt.
