carbon footprint
New Member
Hello,
I'm rather hoping somebody can offer some advice or words or wisdom here...
About a year ago, I bought a Shetland 570 with an inboard OMC sterndrive setup. On the first trip out, the engine started billowing black smoke and everything stopped - it turned out it had overheated and seized.
I had the engine rebuilt and, this week, finally finished rewiring it all and decided to test the electrics. I was fairly happy to find the battery still had enough charge to lower the drive leg, but not quite as happy to discover oil pouring out of the water intake just above the prop shaft...
This is the first time I've lowered the leg since the stupid thing blew up, so I assume this is symptomatic of the reason why. I also assume that a seal has gone on the drive shaft and the oil had pooled around the impellor, waiting for the day I lowered the leg and it could all drain out...
The sterdrive is a Stringer 400/800 model number 980701, serial number 120B 4290 - it is, indeed, the same sterndrive as Noah fitted to the Ark (I'm reliably informed). On the off-chance that somebody out there knows how these things work, I'd be very interested to know what they think has happened and, to the nearest power of ten, how much it's likely to cost to repair.
Any thoughts, comments or sage stroking of beards will be much appreciated,
Many thanks,
Paul
Many thanks,
Paul
